[GRASS5] documentation
Helena Mitasova hmitaso at unity.ncsu.edu
Wed Apr 24 13:12:25 EDT 2002
Moritz Lennert wrote:
> On Wed, Apr 24, 2002 at 11:43:33AM +0200, Markus Neteler wrote:
> > On Wed, Apr 24, 2002 at 10:28:52AM +0200, Moritz Lennert wrote:
> > > On Tue, Apr 23, 2002 at 09:12:56PM -0500, Helena wrote:
> > > > > start a general review of everything that is available, merge usable
> > > > > stuff and write whatever is needed.
> > > > So I really believe that instead of trying to fix the old book (which
> > > > would be a monumental work, as it requires much more than polishing), it
> > > > would be actually faster and better to write new on-line tutorial based
> > > > on the latest GRASS5 release, rather than rely on GRASS4* materials. We
> > > > have already set it up, I think that Markus has a link to it.
> > > There already is a new tutorial ?
> > You can find an outlined version here:
> > http://grass.itc.it/gdp/grass5tutor/
> > This must be filled with contents now.
> > Eventually we should use "docbook" or something
> > similar (http://www.docbook.org/)
> It looks good. however, it is data oriented, not task oriented as
> Helena suggested.
Moritz I am changing the outline right now to task oriented. I will submit the
change
to CVS and Markus can set-up automated update of the web document. New items or
themes
can always be added but it would be good to have a good basic structure.
Are you able to use CVS? If yes, you could get the manual after I fix the outline
and you can start updating the first sections. You can also use these first
sections
to test the coordination with the french effort .
Markus I think that we should change the copyright there on GRASS documentation
team
or something like that.
Helena
