[GRASS5] Script to build babyGRASS for handhelds
Glynn Clements
glynn.clements at virgin.net
Wed Apr 24 12:59:37 EDT 2002
Markus Neteler wrote:
> > > If you're looking to save memory, generate stripped binaries, e.g.
> > > You could also try optimising for size:
> > Both good points.
> Thanks - have update that. I currently face the problem that
> mk/vars.mk
> does not get the prefix/bindir from configure. But that's
> eventually not yet implemented (will find a workaround).
What use would that be?
The only part of the build process which should need to know the
prefix is the "install" target.
Glynn Clements <glynn.clements at virgin.net>
