[GRASS5] documentation
Moritz Lennert
fa1079 at qmul.ac.uk
Wed Apr 24 13:33:36 EDT 2002
On Wed, Apr 24, 2002 at 01:12:25PM -0400, Helena Mitasova wrote:
> Moritz I am changing the outline right now to task oriented. I will submit the
> change
> to CVS and Markus can set-up automated update of the web document. New items or
> themes
> can always be added but it would be good to have a good basic structure.
I agree. We should try to rapidly have a fixed list of keywords (while
staying flexible obviously).
> Are you able to use CVS? If yes, you could get the manual after I fix the outline
Yes, CVS is ok. I just need to get write access once we start working
on it.
> and you can start updating the first sections. You can also use these first
> sections
> to test the coordination with the french effort .
Ok, I'm still waiting for feedback from their side.
Moritz
