[GRASS5] can't latex progmanual
Moritz Lennert
fa1079 at qmul.ac.uk
Mon Apr 29 10:10:41 EDT 2002
Here's the output of make 2>&1 | tee ProgmanCompile.log, but again, I
don't see much of an error message, except at the end.
Moritz
On Mon, Apr 29, 2002 at 03:21:47PM +0200, Markus Neteler wrote:
> Moritz,
> On Mon, Apr 29, 2002 at 03:25:03PM +0200, Moritz Lennert wrote:
> > Hi there,
> > I have trouble latexing the programmer's manual. It exits with
> > make: *** [all] Erreur 139.
> > I'm using:
> > TeX (Web2C 7.3.7) 3.14159
> > kpathsea version 3.3.7
> > on Debian Woody
> > I've attached the log file. I'm really no latex expert, so I don't
> > really understand what is wrong.
> the log file you have send does not contain an error, it
> seems to be cut. Please send a full log.
> Here it compiles fine...
> Markus
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
echo Rerun > progmangrass50.log
while grep Rerun progmangrass50.log >/dev/null 2>&1 ; do latex progmangrass50.tex ; done
This is TeX, Version 3.14159 (Web2C 7.3.7)
(./progmangrass50.tex
LaTeX2e <2001/06/01>
Babel <v3.7h> and hyphenation patterns for american, french, german, ngerman, n
ohyphenation, loaded.
(./scrbook.cls
Document Class: scrbook 1999/12/29 v2.5h LaTeX2e KOMA document class
(/usr/share/texmf/tex/latex/base/bk11.clo) (./typearea.sty
Package: typearea, Copyright (C) Frank Neukam, 1992-1994
Copyright (C) Markus Kohm, 1994-1999
)) (/usr/share/texmf/tex/latex/base/fontenc.sty
(/usr/share/texmf/tex/latex/base/t1enc.def)) (./progmangrass50.sty
(/usr/share/texmf/tex/generic/babel/babel.sty
(/usr/share/texmf/tex/generic/babel/english.ldf
(/usr/share/texmf/tex/generic/babel/babel.def)))
(/usr/share/texmf/tex/latex/graphics/graphicx.sty
(/usr/share/texmf/tex/latex/graphics/keyval.sty)
(/usr/share/texmf/tex/latex/graphics/graphics.sty
(/usr/share/texmf/tex/latex/graphics/trig.sty)
(/usr/share/texmf/tex/latex/config/graphics.cfg)
(/usr/share/texmf/tex/latex/graphics/dvips.def))) (./longtable.sty)
(/usr/share/texmf/tex/latex/base/makeidx.sty)
Writing index file progmangrass50.idx
(/usr/share/texmf/tex/latex/psnfss/times.sty) (./xspace.sty)
(/usr/share/texmf/tex/latex/fancyvrb/fancyvrb.sty
Style option: `fancyvrb' v2.7, with DG/SPQR fixes <2000/03/21> (tvz))
(/usr/share/texmf/tex/latex/base/ifthen.sty)
(/usr/share/texmf/tex/latex/hyperref/hyperref.sty
(/usr/share/texmf/tex/latex/hyperref/pd1enc.def)
Implicit mode ON; LaTeX internals redefined
(./url.sty))
*hyperref using driver hdvips*
(/usr/share/texmf/tex/latex/hyperref/hdvips.def
(/usr/share/texmf/tex/latex/hyperref/pdfmark.def)))
No file progmangrass50.aux.
(/usr/share/texmf/tex/latex/psnfss/t1ptm.fd)
(/usr/share/texmf/tex/latex/graphics/color.sty
(/usr/share/texmf/tex/latex/config/color.cfg)
(/usr/share/texmf/tex/latex/graphics/dvipsnam.def))
(/usr/share/texmf/tex/latex/hyperref/nameref.sty)
Overfull \hbox (341.43307pt too wide) in paragraph at lines 42--42
Overfull \hbox (341.43307pt too wide) in paragraph at lines 45--45
[1] [2] [3]
Overfull \hbox (0.90271pt too wide) in paragraph at lines 120--133
\T1/ptm/m/n/10.95 GRASS (Ge-o-graph-i-cal Re-sources Anal-y-sis Sup-port Sys-te
m) is a com-pre-hen-sive GIS with raster,
(/usr/share/texmf/tex/latex/psnfss/omsptm.fd)
Underfull \hbox (badness 10000) in paragraph at lines 141--142
(/usr/share/texmf/tex/latex/psnfss/t1pcr.fd)
LaTeX Warning: Reference `gfd_license' on page 4 undefined on input line 145.
Underfull \hbox (badness 10000) in paragraph at lines 143--146
[4]
Underfull \hbox (badness 10000) in paragraph at lines 192--198
Underfull \hbox (badness 10000) in paragraph at lines 199--200
Underfull \hbox (badness 10000) in paragraph at lines 201--202
Underfull \hbox (badness 10000) in paragraph at lines 203--204
[1]
Underfull \hbox (badness 10000) in paragraph at lines 229--236
Underfull \hbox (badness 10000) in paragraph at lines 237--238
[2] (./status.tex
Underfull \hbox (badness 10000) in paragraph at lines 1--2
Underfull \hbox (badness 10000) in paragraph at lines 3--4
[3]
Underfull \vbox (badness 10000) has occurred while \output is active [4])
[5] (./TODO [6]
Underfull \vbox (badness 10000) has occurred while \output is active [7])
[8] (./chapter1.tex [1] [2]
Chapter 1.
Underfull \hbox (badness 10000) in paragraph at lines 49--59
Underfull \vbox (badness 10000) has occurred while \output is active [3]
Underfull \hbox (badness 10000) in paragraph at lines 90--95
[4]
LaTeX Warning: Reference `GRASS_Information_Center' on page 5 undefined on inpu
t line 118.
t line 118.
t line 118.
Underfull \hbox (badness 10000) in paragraph at lines 136--137
[5]
Overfull \hbox (6.78607pt too wide) in alignment at lines 169--194
Package longtable Warning: Column widths have changed
(longtable) in table 1.1 on input line 194.
) (./chapter2.tex [6]
Chapter 2.
Underfull \hbox (badness 10000) in paragraph at lines 14--21
Underfull \hbox (badness 10000) in paragraph at lines 22--28
Underfull \hbox (badness 10000) in paragraph at lines 29--36
Underfull \hbox (badness 10000) in paragraph at lines 37--45
Underfull \hbox (badness 10000) in paragraph at lines 46--50
Underfull \hbox (badness 10000) in paragraph at lines 51--55
Underfull \hbox (badness 10000) in paragraph at lines 56--58
Underfull \hbox (badness 10000) in paragraph at lines 59--62
Underfull \hbox (badness 10000) in paragraph at lines 63--68
Underfull \hbox (badness 10000) in paragraph at lines 69--76
Underfull \hbox (badness 10000) in paragraph at lines 80--81
Underfull \hbox (badness 10000) in paragraph at lines 82--87
Underfull \hbox (badness 10000) in paragraph at lines 88--92
[8]
Underfull \hbox (badness 10000) in paragraph at lines 93--96
Underfull \hbox (badness 10000) in paragraph at lines 97--98
LaTeX Warning: Reference `Compiling_and_Installing_GRASS_Modules' on page 9 und
efined on input line 124.
LaTeX Warning: Reference `GRASS_CVS_repository' on page 9 undefined on input li
ne 141.
ne 141.
ne 141.
Underfull \vbox (badness 1888) has occurred while \output is active [9]
Overfull \hbox (3.63167pt too wide) in paragraph at lines 153--156
[]\T1/ptm/m/it/10.95 Source code \T1/ptm/m/n/10.95 -- The source code for the f
unc-tions should be ac-com-pa-nied by lib-eral amounts
LaTeX Warning: Reference `UNIX_Environment' on page 10 undefined on input line
172.
172.
172.
) (./chapter3.tex [10]
Chapter 3.
Underfull \hbox (badness 10000) in paragraph at lines 21--42
[11]
Underfull \hbox (badness 10000) in paragraph at lines 96--105
Underfull \hbox (badness 10000) in paragraph at lines 107--113
[12]
LaTeX Warning: Reference `Writing_GRASS_Shell_Scripts' on page 13 undefined on
input line 120.
input line 120.
input line 120.
Underfull \hbox (badness 10000) in paragraph at lines 115--121
Underfull \hbox (badness 10000) in paragraph at lines 122--128
LaTeX Warning: Reference `Compiling_and_Installing_GRASS_Modules' on page 13 un
defined on input line 139.
Underfull \hbox (badness 10000) in paragraph at lines 130--140
LaTeX Warning: Reference `GIS_Library' on page 13 undefined on input line 155.
LaTeX Warning: Reference `Vector_Library' on page 13 undefined on input line 16
7.
7.
7.
[13]
LaTeX Warning: Reference `Segment_Library' on page 14 undefined on input line 1
73.
73.
73.
LaTeX Warning: Reference `Vask_Library' on page 14 undefined on input line 182.
LaTeX Warning: Reference `Display_Graphics_Library' on page 14 undefined on inp
ut line 200.
ut line 200.
ut line 200.
LaTeX Warning: Reference `Raster_Graphics_Library' on page 14 undefined on inpu
t line 200.
t line 200.
t line 200.
LaTeX Warning: Reference `Writing_a_Graphics_Driver' on page 14 undefined on in
put line 218.
put line 218.
put line 218.
LaTeX Warning: Reference `Digitizer_Mouse_Trackball_Files' on page 14 undefined
on input line 223.
on input line 223.
on input line 223.
LaTeX Warning: Reference `Writing_a_Paint_Driver' on page 14 undefined on input
line 225.
line 225.
line 225.
[14]) (./chapter4.tex [15] [16]
Chapter 4.
LaTeX Warning: Reference `GIS_Library' on page 17 undefined on input line 16.
LaTeX Warning: Reference `GIS_Library' on page 17 undefined on input line 24.
LaTeX Warning: Reference `Environment_Variables' on page 17 undefined on input
line 26.
line 26.
line 26.
Underfull \hbox (badness 10000) in paragraph at lines 15--28
LaTeX Warning: Reference `Writing_GRASS_Shell_Scripts' on page 17 undefined on
input line 31.
input line 31.
input line 31.
Overfull \hbox (12.22581pt too wide) in paragraph at lines 49--55
\T1/ptm/m/n/10.95 Subdirectories un-der the GIS-D-BASE are known as lo-ca-tions
. Lo-ca-tions are in-de-pen-dent databases.
Underfull \vbox (badness 4144) has occurred while \output is active [17]
(/usr/share/texmf/tex/latex/psnfss/t1phv.fd)
LaTeX Warning: Reference `Database_Access_Rules' on page 18 undefined on input
line 102.
line 102.
line 102.
Underfull \hbox (badness 10000) in paragraph at lines 98--104
[18]
Overfull \hbox (31.89261pt too wide) in paragraph at lines 107--109
[]\T1/ptm/m/n/10.95 $GISDBASE/$LOCATION_NAME/$MAPSET and is re-turned by the li
-brary rou-tine G_location_path.
LaTeX Warning: Reference `Permanent_Mapset' on page 19 undefined on input line
115.
115.
115.
LaTeX Warning: Reference `Region' on page 19 undefined on input line 160.
Underfull \vbox (badness 2443) has occurred while \output is active [19]
LaTeX Warning: Reference `Mapset_Search_Path' on page 20 undefined on input lin
e 168.
e 168.
e 168.
LaTeX Warning: Reference `Creating_and_Opening_a_New_Database_File' on page 20
undefined on input line 177.
[20]
(longtable) in table 4.1 on input line 230.
Underfull \hbox (badness 10000) in paragraph at lines 241--245
Underfull \hbox (badness 10000) in paragraph at lines 246--248
Underfull \hbox (badness 10000) in paragraph at lines 249--253
Underfull \hbox (badness 10000) in paragraph at lines 254--255
Underfull \vbox (badness 6825) has occurred while \output is active [21]
LaTeX Warning: Reference `Mapsets' on page 22 undefined on input line 266.
LaTeX Warning: Reference `Mapset_Search_Path' on page 22 undefined on input lin
e 271.
e 271.
e 271.
LaTeX Warning: Reference `UNIX_File_Permissions' on page 22 undefined on input
line 272.
line 272.
line 272.
[22] [23]
Underfull \vbox (badness 10000) has occurred while \output is active [24])
(./chapter5.tex [25] [26]
Chapter 5.
(longtable) in table 5.1 on input line 153.
[27]
LaTeX Warning: Reference `Mapsets' on page 28 undefined on input line 184.
LaTeX Warning: Reference `Raster_File_Processing' on page 28 undefined on input
line 188.
line 188.
line 188.
LaTeX Warning: Reference `Multibyte_data_format' on page 28 undefined on input
line 213.
Underfull \vbox (badness 10000) has occurred while \output is active [28]
Underfull \hbox (badness 10000) in paragraph at lines 244--248
[29]
LaTeX Warning: Reference `Raster_Header_File' on page 30 undefined on input lin
e 295.
e 295.
e 295.
Overfull \hbox (0.53217pt too wide) in paragraph at lines 343--348
[]\T1/ptm/m/n/10.95 The ge-o-graphic bound-aries of the raster file are de-scri
bed by the \T1/ptm/m/it/10.95 north,
[30]
Underfull \hbox (badness 10000) in paragraph at lines 386--388
Underfull \hbox (badness 10000) in paragraph at lines 391--392
Underfull \hbox (badness 10000) in paragraph at lines 393--396
Underfull \vbox (badness 5189) has occurred while \output is active [31]
Underfull \hbox (badness 10000) in paragraph at lines 469--471
LaTeX Warning: Reference `Raster_Category_File' on page 32 undefined on input l
ine 473.
ine 473.
ine 473.
Underfull \hbox (badness 10000) in paragraph at lines 472--474
[32]
Underfull \hbox (badness 10000) in paragraph at lines 492--493
(longtable) in table 5.2 on input line 572.
[33] [34]
LaTeX Warning: Reference `Raster_Color_Table' on page 35 undefined on input lin
e 637.
e 637.
e 637.
Underfull \hbox (badness 10000) in paragraph at lines 636--638
Underfull \hbox (badness 10000) in paragraph at lines 643--645
[35]
LaTeX Warning: Reference `Raster_History_File' on page 36 undefined on input li
ne 683.
ne 683.
ne 683.
LaTeX Warning: Reference `Raster_Range_File' on page 36 undefined on input line
700.
700.
700.
Underfull \hbox (badness 10000) in paragraph at lines 709--710
[36]
Overfull \hbox (46.03969pt too wide) in paragraph at lines 734--742
\T1/ptm/m/n/10.95 tines: G_something_raster (..., void *raster, RASTER_MAP_TYPE
type, ...) G_something_c_raster
Overfull \hbox (62.51988pt too wide) in paragraph at lines 734--742
\T1/ptm/m/n/10.95 G_something_null_value (..., void *raster, RASTER_MAP_TYPE ty
pe, ...) G_something_c_null_value
Overfull \hbox (39.6557pt too wide) in paragraph at lines 734--742
\T1/ptm/m/n/10.95 (..., CELL *cell, ...) G_something_f_null_value (..., FCELL *
fcell, ...) G_something_d_null_value
[37]
Overfull \hbox (5.2423pt too wide) in paragraph at lines 835--837
[]\T1/ptm/m/n/10.95 This bi-nary file con-tains the range (min-i-mum and max-
[38]) (./chapter6.tex [39] [40]
Chapter 6.
Overfull \hbox (0.83908pt too wide) in paragraph at lines 7--9
\T1/ptm/m/n/10.95 This chap-ter pro-vides an ex-pla-na-tion of how vec-tor map
lay-ers are ac-com-mo-dated in the GRASS
Underfull \hbox (badness 10000) in paragraph at lines 13--19
Underfull \hbox (badness 10000) in paragraph at lines 20--32
LaTeX Warning: Reference `What_is_a_Raster_Map_Layer' on page 41 undefined on i
nput line 39.
nput line 39.
nput line 39.
Underfull \hbox (badness 10000) in paragraph at lines 33--41
LaTeX Warning: Reference `Mapsets' on page 41 undefined on input line 46.
Underfull \hbox (badness 10000) in paragraph at lines 42--47
[41]
Overfull \hbox (1.2103pt too wide) in paragraph at lines 61--64
[]\T1/ptm/m/n/10.95 For ex-am-ple, a map layer named \T1/ptm/m/it/10.95 soils \
T1/ptm/m/n/10.95 would have the files \T1/ptm/m/it/10.95 dig\T1/ptm/m/n/10.95 /
\T1/ptm/m/it/10.95 soils, dig_att\T1/ptm/m/n/10.95 /\T1/ptm/m/it/10.95 soils, d
ig_plus/soils,
Underfull \hbox (badness 10000) in paragraph at lines 75--77
Underfull \hbox (badness 10000) in paragraph at lines 78--81
LaTeX Warning: Reference `Vector_Library' on page 42 undefined on input line 83
