[GRASS5] Script to build babyGRASS for handhelds
Markus Neteler neteler at itc.it
Tue Apr 30 06:24:35 EDT 2002
meanwhile we have compiled a binary version for iPAQ on
the skiff-cluster (I fixed some bugs in my script).
Only one lib cannot be compiled, the gcc crashes:
./gmake5 src/libes/dig_atts
make: Entering directory
'/home/guest/stankovic at itc.it/babyGRASS_src/src/libes/dig_atts'
mkdir -p /home/guest/stankovic at itc.it/babyGRASS_src/src/libes/dig_atts
make -f makefile
make[1]: Entering directory
gcc -shared -o
/home/guest/stankovic at itc.it/babyGRASS_src/src/libes/libgrass_dig_atts.so.5.0.0
/home/guest/stankovic at itc.it/babyGRASS_src/src/libes/dig_atts/atts_init.o
/home/guest/stankovic at itc.it/babyGRASS_src/src/libes/dig_atts/read_att.o
/home/guest/stankovic at itc.it/babyGRASS_src/src/libes/dig_atts/write_att.o
-L/home/guest/stankovic at itc.it/babyGRASS_src/src/libes
-Wl,-rpath-link,/home/guest/stankovic at itc.it/babyGRASS_src/src/libes -s
-lgrass_gis && ln -sf libgrass_dig_atts.so.5.0.0
collect2: ld terminated with signal 11 [Segmentation fault], core dumped
make[1]: ***
[/home/guest/stankovic at itc.it/babyGRASS_src/src/libes/libgrass_dig_atts.so.5.0.0]
Error 1
make[1]: Leaving directory
make: *** [dir] Error 2
make: Leaving directory
Architecture is:
uname -a
Linux skiffcluster4.handhelds.org 2.4.0-test1-ac7-rmk1-crl2 #15 Fri Jun 16
11:24:53 EDT 2000 armv4l unknown
I don't know what I can do, the libgrass_dig_atts.so is needed for all
vector libs and modules. As far as I know such signal 11 is worst case...
All other libs compile (except for the libgrass_dig_atts.so dependency).
Markus
