[GRASS5] Making GRASS cross-compiler friendly (was: Script to
build babyGRASS for handhelds)
Carl Worth
cworth at east.isi.edu
Tue Apr 30 13:58:54 EDT 2002
On Apr 30, Frank Warmerdam wrote:
> I don't think nad2bin is executed at runtime by GRASS, but it can be
> important that the nad2bin that is executed be one that matches the
> architecture that will be using the output binary files. Note that this
> isn't just an endian issue, the produced binary files will also be useless
> if structure packing is different on the different architectures.
Good point. This is of course true, (and likely to bite me in the x86
vs. arm case).
> I personally think that PROJ.4 ought to work towards a new architecture
> independent format for the grid shift files. This really wouldn't be hard.
> or significantly impair performance.
I agree.
-Carl
