[GRASS5] [patch] resize bug in X monitor
Glynn Clements
glynn.clements at virgin.net
Tue Apr 30 14:56:19 EDT 2002
Magnus B{ckstr|m wrote:
> the below patch corrects a bunnyhop error in XDRIVER and updates
> G_malloc() a little.
> The bunnyhop error caused a bus error when resizing an X monitor on
> freebsd,
OK; I'll fix that.
> and the update to G_malloc() ensures that returned memory
> is initialized to zeros (which not all malloc()s can be trusted to
> do).
This shouldn't be necessary. Code which requires that the memory is
zeroed should call G_calloc().
Glynn Clements <glynn.clements at virgin.net>
