[GRASS5] [bug #1219] (grass) r.support/range bug
Request Tracker grass-bugs at intevation.de
Fri Aug 2 03:58:25 EDT 2002
this bug's URL: http://intevation.de/rt/webrt?serial_num=1219
Subject: r.support/range bug
grass obtained from: CVS
grass binary for platform: Compiled from Sources
a bug report... r.support seems not to calculate the range properly (minimum always set to 0).
Some test:
g.region -pa res=100
projection: 99 (Transverse Mercator)
zone:       0
datum:      rome40
ellipsoid:  international
north:      5136900
south:      5131800
west:       1649000
east:       1655400
nsres:      100
ewres:      100
rows:       51
cols:       64
r.mapcalc test="10+row()"
test = (add(10,row()))
 100%
r.info test
Data Type:    CELL
Range of data:    min =  11 max = 61
So far so nice. But:
r.support -r test
  Updating the stats for [test]
r.info test
Data Type:    CELL
Range of data:    min =  0 max = 61
Oops. The range update is wrong inside
src/raster/r.support/cmd/check.c
Next test with FP
r.mapcalc testfp="10.1+row()"
test = (add(10.100000,double(row())))
 100%
r.info testfp
Data Type:    DCELL
Range of data:    min =  11.100000 max = 61.100000
r.support -r testfp
  Updating the stats for [testfp]
   Updating the number of categories for [testfp]
r.info testfp
Data Type:    DCELL
Range of data:    min =  0.000000 max = 61.000000
It seems that r.mapcalc knows how to calculate the range properly, while r.support doesn't.
Markus
-------------------------------------------- Managed by Request Tracker
