[GRASS5] Re: grass5 digest, Vol 1 #435 - 2 msgs
andy agena
andya at mac.com
Wed Aug 7 10:05:06 EDT 2002
hello:
i think that you want:
TCLTKGRASSBASE: /usr/local/grass5/bin/tcltkgrass
in your ~/.grassrc5 instead of:
TCLTKGRASSBASE: /sw/grass5/tcltkgrass
as i installed GRASS in my Fink directory.
Take care,
Andy
On Wednesday, August 7, 2002, at 05:01 AM, grass5-request at grass.itc.it
wrote:
> Message: 1
> Date: Wed, 7 Aug 2002 10:23:33 +0200
> From: Markus Neteler <neteler at itc.it>
> To: grass5 developers list <grass5 at grass.itc.it>
> Subject: [GRASS5] [eyreka at mac.com: more onTclTkGRASS troubles]
> Hi,
> attached a lady with tcltkgrass problems on MacOSX.
> Does anyone have a suggestion for her?
> Thanks,
> Markus
> Hello again,
> Still having problems with TlcTkGRASS. I referred to discussions
> suggested by Markus and particularly to bit about adding
> 'TCLTKGRASSBASE: /sw/grass5/tcltkgrass' to .grassrc5 but also noted that
> what I am interpreting as the TclTkGRASS script, tcltkgras.tcl (typed in
> red on attached rtf file), is missing lines shown on
> 'http://grass.itc.it/pipermail/grass5/2002-June/003464.html' and
> repeated by me (also in red print) at the end of attached file. Could
> this be source of my problem?
> From original message:
>> Hello,
>> I just got around to installing my update of GRASS 5.0.0pre4 from
>> OpenOSX and find I've a problem with the TlcTkGRASS gui. I don't
>> currently use the GUI but will want to do so and would appreciate any
>> help getting it going again.
>> When I give the command tlctkgrass& as below
>> GRASS 5.0.0pre4 > tcltkgrass&
>> the main menu bar briefly appears and then I get the message:
