[GRASS5] Re: latex for code documentation
Markus Neteler
neteler at itc.it
Mon Aug 12 09:40:30 EDT 2002
Helena, all,
(cc grass5)
[question was: how to document algorithm within the source code]
On Sun, Aug 11, 2002 at 02:49:26PM -0400, Helena wrote:
> I checked with Lubos,
> for the C++ code they indeed use doxygen (I noticed that GDAL uses it
> too), but he also found the following, downloaded it and tried it out and
> it worked pretty well in spite of the fact that it is listed as unstable.
> src2tex
> What: src2tex
> Where: http://www.cc.gunma-u.ac.jp/%7Eamano/kamano.html - This site no
> longer found
> http://packages.debian.org/unstable/tex/src2tex.html
> Description: Text converter from at least 24 different types of source
> code into LaTeX. Permits not only pretty printing, but also
> recognizes math formulae in comment areas of the programs, patch
> in PostScript or Encapsulated PostScript images into resulting TeX
> file, allows one to easily incorporate documentation and manuals
> with source code, and allows for attractive output of source for
> reference purposes.
> Updated: 07/2002
> Contact: mailto:kamano at po.iijnet.or.jp (Kazuo AMANO)
> mailto:m93093 at euclides.josai.ac.jp (Shinichi NOMOTO)
> The overview of all the efforts is here:
> http://tex.loria.fr/english/litte.html
> but Lubos says that he found only src2tex simple enough and functional.
I looks at src2[la]tex briefly, looks nice and simple to use.
Perhaps other developers can try it as well?
Markus
