[GRASS5] i.tm.dehaze problem
Markus Neteler neteler at itc.it
Mon Aug 12 10:55:19 EDT 2002
On Mon, Aug 12, 2002 at 04:48:09PM +0200, Markus Neteler wrote:
> On Sat, Aug 10, 2002 at 07:21:14PM +0100, Gualter Barbas Baptista wrote:
> > -----BEGIN PGP SIGNED MESSAGE-----
> > Hash: SHA1
> > Hi,
> > I'm trying to run the i.tm.dehaze but I'm getting the errors below. Does
> > anyone know what this means and how can be solved? I'm running
> > 5.0.0pre3, could this be some old bug?
> > GRASS:~ > i.tm.dehaze inverno.tasscap.4 b1 b2 b3 b4 b5 b7
> > r.stats:  100%
> > 1 variables
> > 0 observations
> > ERROR: SVDCMP: You must augment A with extra zero rows
> Hi,
> this looks as a problem r.linear.regression. It is suspicious that
> there are '0 observations'.
> Are you sure that you work in a region with data (check with d.erase;d.rast)?
> Note that i.tm.dehaze is a script without good error testing.
Ok, I have submitted a simple error test which stop the script
when r.linear.regression stops due to erratic input.
Try i.tm.dehaze with a smaller region first. The input size is
somewhat limited according to the machine's resources where GRASS
is running on.
With my TM data it runs well.
Markus
