[GRASS5] Re: [GRASSLIST:4315] Re: s.surf.rst output extent (wrap up)
Bernhard Reiter
bernhard at intevation.de
Mon Aug 19 06:41:44 EDT 2002
On Mon, Aug 19, 2002 at 12:28:22PM +0200, Markus Neteler wrote:
> a cross-post from grasslist:
> Should we consider to force a chmod to write permission enabled for user
> in case a map is set to read-only (example see below)?
We should add a permission check and issue a warning.
I'm not sure that forcing a permission is a good idea.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020819/2b626b26/attachment.bin
