[GRASS5] Re: [GRASSLIST:4315] Re: s.surf.rst output extent (wrap up)
Russell Nelson nelson at crynwr.com
Mon Aug 19 10:17:55 EDT 2002
Markus Neteler writes:
 > a cross-post from grasslist:
 > Should we consider to force a chmod to write permission enabled for user
 > in case a map is set to read-only (example see below)?
What if it was *supposed* to be read-only?  Better to say why the file
write failed.  "You own that file, but you don't have write permission
for it.  Consider using chmod."
-russ nelson              http://russnelson.com |
Crynwr sells support for free software  | PGPok | businesses persuade
521 Pleasant Valley Rd. | +1 315 268 1925 voice | governments coerce
Potsdam, NY 13676-3213  | +1 315 268 9201 FAX   |
