[GRASS5] Re: [GRASSLIST:4357] merge of lines
Silke Reimer silke at intevation.de
Thu Aug 22 09:49:35 EDT 2002
On Thu, Aug 22, 2002 at 01:17:22PM +0200, Markus Neteler wrote:
> On Thu, Aug 22, 2002 at 01:13:31PM +0200, Bernhard Reiter wrote:
> > It seems that there is not option in v.digit -> edit
> > to join two lines that share a node.
> > Is there a reason for this in the data model?
> > It should be fairly easy to do.
> > Like if I have two lines .= vertices X=node shared by both lines
> > 	.----.----X--.--.
> > to join the lines to
> > If I wanted to add this, what would I have to do?
> Here 'snapping' should help. Either v.support or v.digit,
> select a very small threshold.
We tried out to use either v.support or v.digit but snapping only
snaps 2 nodes to 1 single node (or to 2 nodes at the same
location).
We would rather like to convert a node, shared by 2 lines, to a
vertex
of a single line (like Bernhard tried to demonstrate).
Any suggestions? Or perhaps any reason why it isn't sensible to do
so?
Silke
Silke Reimer
Intevation GmbH                      http://intevation.de/
FreeGIS                                http://freegis.org/
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020822/1a2fb30c/attachment.bin
