[GRASS5] [bug #1238] (grass) r.transect_no_result
Request Tracker grass-bugs at intevation.de
Thu Aug 22 11:15:25 EDT 2002
this bug's URL: http://intevation.de/rt/webrt?serial_num=1238
Subject: r.transect_no_result
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
GRASS Version: 5.0pre4
Please enter error description here (and your name)
I did not get any results with r.transect.
Could you please change in source code main.c
line 85 and 86 from:
sprintf (command, "r.profile map='%s' width=%s result=%s
line=",
parms.map->answer, parms.width->answer,
parms.result->answer);
to updated command of r.profile for example:
   sprintf (command, "r.profile input='%s' output=-
profile=",
	parms.map->answer);
Then it'll be fixed.
ciao
Hans Fuchs
-------------------------------------------- Managed by Request Tracker
