[GRASS5] Re: [GRASS-CVS] markus: grass/src/imagery/i.ortho.photo/photo.rectify write.c,1.2,1.3
Bernhard Reiter bernhard at intevation.de
Fri Aug 23 10:23:52 EDT 2002
On Fri, Aug 23, 2002 at 04:14:10PM +0200, Markus Neteler wrote:
> On Fri, Aug 23, 2002 at 03:59:18PM +0200, Markus Neteler wrote:
> > On Fri, Aug 23, 2002 at 03:49:46PM +0200, Bernhard Reiter wrote:
> > > To help diagnosing this it might be helpful to give the filename
> > > in the error message where writing was attempted.
> > > I would replace the "(disk full?)" comment by
> > > ". You might want to check available disk space and write permissions."
> > submitted. thanks.
> It may be even nice to see *which* partition is full.
This is why I think you should output the filename
in question, it would allow analysis. :)
> At least here it's difficult, we have a complicated mixture
> of NFS linked machines with lot's of partitions. Is there
> a portable method to print which partition is full?
Not that I know.
	"df" and "mount" help a lot on many unix machines.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020823/dc4cee73/attachment.bin
