Eric G. Miller wrote: > Should "make clean" remove src/include/version.h and > src/include/winname.h ? Doing so breaks recompilation without > running configure again (but the point of "clean" is to keep the > configuration...). Shouldn't that removal be moved to distclean? Yes, it should. -- Glynn Clements <glynn.clements at virgin.net>
