[GRASS5] [bug #1465] (grass) v.proj datum conversion fails. Typo in code main.c
Request Tracker
grass-bugs at intevation.de
Mon Dec 2 12:18:53 EST 2002
this bug's URL: http://intevation.de/rt/webrt?serial_num=1465
Subject: v.proj datum conversion fails. Typo in code main.c
Platform: Solaris2.X/Sparc
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
GRASS Version: 5.0.0
v.proj does not work for datum conversions because of a bug in the code in main.c. Changing:
/* for datum conversion find output location datum and ellipse */
*out_datum='\0';
if((hold=G_database_datum_name()))
strncpy(out_datum,hold,sizeof(out_datum));
*in_datum='\0';
strncpy(in_datum,hold,sizeof(in_datum));
to:
*out_datum='\0';
*out_ellipse='\0'; <------
if((hold=G_database_ellipse_name())) <------
strncpy(out_ellipse,hold,sizeof(out_ellipse)); <------
appears to fix problem.
You will see "Shifting NAD83->NAD27" or "Shifting NAD27->NAD83" message if shift occurs (from datum_shift.c). Currently this doesn't happen because the output datum information doesn't get set correctly.
Also, I modified v.proj tcltk module to:
interface_build {
{v.proj} 0
{Allows projection conversion of vector files.}
{entry input {Input vector map:} 0 vector}
{entry output {Output vector map [input name]:} 0 vector}
{entry dbase {GRASS database containing INPUT location [current database]:} 0 ""}
{entry mapset {GRASS mapset containing INPUT vector map [current mapset]:} 0 ""}
{entry location {Location containing INPUT vector map:} 0 ""}
{checkbox -s {Automatically run v.support} "" -s}
{checkbox -l {list vector files in input location} "" -l}
but the -l feature does NOT work in tcltk. It does work on command line.
John Gillette
-------------------------------------------- Managed by Request Tracker
