[GRASS5] grass-5.0.0 on SGI IRIX 6.5 (fwd)
Paul Kelly paul-grass at stjohnspoint.co.uk
Tue Dec 10 05:38:59 EST 2002
On Tue, 10 Dec 2002, Glynn Clements wrote:
> Markus Neteler wrote:
> > > The only problem is the Escape and Return keys not working when run from
> > > an IRIX winterm. I at least should have proposed a change to the README on
> > > the ftp server to mention this; sorry. The partial fix for this has now been
> > > merged into the release branch, but still it means the arrow keys don't work
> > > now. I was waiting until we got this sorted out before compiling another binary
> > > package.
> > The arrow keys are also broken for me: Linux, HEAD, at least in
> > the startup script. Broken in xterm as well as KDE-term. This is a bit
> > odd, because it was working and I like the keys. I can report that
> > for Suse 7.3 and Redhat 7.1 (with updates).
> > Does it have to do with the recent TERMLIB changes?
> Possibly. There are two different databases of terminal descriptions:
> termcap (typically /etc/termcap) and terminfo (typically
> /usr/lib/terminfo/* or /usr/share/terminfo/*).
/usr/lib/terminfo on IRIX 6.2 as I am using
> Basically, you need to ensure that both databases accurately describe
> the behaviour of the terminal when in "application keypad" mode. (If
> you look at xterm's middle-button menu both normally and when using a
> vask-based input form; in the latter situation, both the "Enable
> Application Cursor Keys" and "Enable Application Keypad" options
> should have tick (check) marks).
For GRASS 4.3:
Neither option ticked, arrow keys don't work, but Esc and Return do work
For GRASS 5.0.0:
"Enable Application Cursor Keys" is ticked, arrow keys do work, but Esc
and Return don't work
For latest CVS version:
(back to GRASS 4.3 behaviour)
Here is some info from my system:
Variations on 'iris' terminfo entry:
iris
iris-ansi
iris-ansi-24
iris-ansi-24-net
iris-ansi-66
iris-ansi-66-net
iris-ansi-net
iris-tp
iris40
Output of 'infocmp iris':
#	Reconstructed via infocmp from file:
/usr/share/lib/terminfo/i/iris-ansi
iris-ansi|IRIS emulating 40 line ANSI terminal (almost VT100),
	am,
	cols#80, it#8, lines#40,
	bel=^G, bold=\E[1m, clear=\E[H\E[2J,
	cnorm=\E[9/y\E[12/y\E[=6l, cr=\r, cub=\E[%p1%dD,
	cub1=\E[D, cud=\E[%p1%dB, cud1=\n, cuf=\E[%p1%dC,
	cuf1=\E[C, cup=\E[%i%p1%d;%p2%dH, cuu=\E[%p1%dA,
	cuu1=\E[A, cvvis=\E[10/y\E[=1h\E[=2l\E[=6h,
	dl=\E[%p1%dM, dl1=\E[M, ed=\E[J, el=\E[K, el1=\E[1K,
	home=\E[H, ht=\t, hts=\EH, il=\E[%p1%dL, il1=\E[L,
	ind=\ED, is2=\E[?1l\E>\E[?7h\E[100g\E[0m\E7\E[r\E8,
	kDC=\E[P, kEND=\E[147q, kHOM=\E[143q, kLFT=\E[158q,
	kPRT=\E[210q, kRIT=\E[167q, kSPD=\E[218q, kbs=\b,
	kcbt=\E[Z, kcub1=\E[D, kcud1=\E[B, kcuf1=\E[C,
	kcuu1=\E[A, kdch1=^?, kend=\E[146q, kent=\r,
	kf1=\E[001q, kf10=\EOQ, kf11=\EOR, kf12=\EOS,
	kf2=\E[002q, kf3=\E[003q, kf4=\E[004q, kf5=\E[005q,
	kf6=\E[006q, kf7=\E[007q, kf8=\E[008q, kf9=\EOP,
	khome=\E[H, kich1=\E[139q, knp=\E[154q, kpp=\E[150q,
	kprt=\E[209q, krmir=\E[146q, kspd=\E[217q, nel=\EE,
	pfkey=\EP101;%p1%d.y%p2%s\E\\, rc=\E8, rev=\E[7m,
	ri=\EM, rmso=\E[m, rmul=\E[m, sc=\E7, sgr0=\E[m,
	smso=\E[1;7m, smul=\E[4m, tbc=\E[3g,
I hope some of this might be useful.
> 	key	t'info	t'cap	sequence
> 	up	kcuu1	ku	\EOA
> 	down	kcud1	kd	\EOB
> 	right	kcuf1	kr	\EOC
> 	left	kcub1	kl	\EOD
> 	home	khome	kh	\EOH
> 	end	kend	@7	\EOF
> When not in application keypad mode, the arrow keys generate the
> cursor motion codes (the ones which an application sends to the
> terminal to move the cursor).
> Also, if the terminal requires a specific sequence to enable
> application mode, that must be specified directly; for xterm, it is:
> 		smkx	ks	\E[?1h\E=
> More information on terminal capabilities can be obtained from the
> termcap, terminfo and ncurses manpages. More information on xterm can
> be obtained from the xterm manpage.
> Glynn Clements <glynn.clements at virgin.net>
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
