[GRASS5] d.vect.area
M Lennert fa1079 at qmul.ac.uk
Fri Feb 1 07:20:18 EST 2002
The following section of this message contains a file attachment
prepared for transmission using the Internet MIME message format.
If you are using Pegasus Mail, or any another MIME-compliant system,
you should be able to save it or view it from within your mailer.
If you cannot, please ask your system administrator for assistance.
   ---- File information -----------
     File:  d~1.cla
     Date:  1 Feb 2002, 13:01
     Type:  Unknown
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020201/96ca00a1/d1.obj
