[GRASS5] Grass 5.0 Pre3 Darwin Report
Glynn Clements glynn.clements at virgin.net
Tue Feb 5 01:56:21 EST 2002
Jeshua Lacock wrote:
> I have successfully built and tested Grass 5.0 pre 3, NVIZ, etc. on Mac
> OS X (Darwin 5.1).
> I just started uploading the binaries to grass.itc.it in the incoming
> directory.
> There is something new that was not happening with previous builds: When
> I execute tcltkgrass I get the following message:
> GRASS 5.0.0pre3 >  called create main window
>   assigning interp 714928
>   tsd is 756320 datakey 756320
>   tsdptr 756320 datakey 756320
>   start search mainPtr 798816
> look for 714928 got 714928
This looks like it's being generated by wish itself. I can't see
anything in the tcltkgrass code which would generate it, and it
doesn't happen on Linux.
> BTW: This build is 122 MB again, I cannot seem to make it smaller, the
> Pre 2 binaries are 50 MB...
Try "make strip". The binaries are no longer stripped automatically.
Glynn Clements <glynn.clements at virgin.net>
