[GRASS5] Deprecate d.area and d.vect.line ??
M Lennert
fa1079 at qmul.ac.uk
Wed Feb 6 05:56:03 EST 2002
> From: Markus Neteler <neteler at itc.it>
> On Tue, Feb 05, 2002 at 07:57:28AM -0800, Eric G. Miller wrote:
> > On Tue, 5 Feb 2002 11:09:36 +0100, Markus Neteler <neteler at itc.it> wrote:
> > > On Mon, Feb 04, 2002 at 05:59:34PM -0800, Eric G. Miller wrote:
> > > > I would like to deprecate d.area (and possibly d.vect.cats ?) in favor of
> > > > d.vect.area. Also, there's the matter of v.area. Do people use it?
> > > > What does it provide that d.what.vect doesn't do (besides the flood
> > > > fill, which doesn't handle islands)?
> > > Yes, please go ahead... But: the d.vect.cats is the upcoming
> > > d.vect. Before you delete I will migrate d.vect.cats to d.vect :-)
> > > Any objections?
> > Oh, okay.
> So.. done. d.vect.cats is now d.vect.
I'm a bit confused: the only difference between the new d.vect and d.vect.line is that the latter
uses a legend file whereas the former only has the catnum option on the command line, or am I
missing something ?
Moritz
