[GRASS5] Re: Pre3 install comments
Glynn Clements
glynn.clements at virgin.net
Wed Feb 6 13:32:09 EST 2002
Markus Neteler wrote:
> > * In src/CMD/lists/GRASS, I noticed that v.in.dlg is listed twice
> > (src/mapdev & src.contrib/SCS/mapdev). Should one be commented out?
> ... does anyone know which version is desired?
Note that the SCS version is called v.in.dlg.scs, so it isn't
overwriting v.in.dlg.
The v.in.dlg.scs manpage says that it is called from v.import, but
v.import actually calls v.in.dlg.
Glynn Clements <glynn.clements at virgin.net>
