Grass GUI (was Re: [GRASS5] Problems with vector import, and a
suggestion)
Carl Worth
cworth at east.isi.edu
Thu Feb 7 16:17:00 EST 2002
On Feb 7, Roger Miller wrote:
> >From the command line--at least as of pre2--when the user creates a
> monitor window, the focus is passed to the monitor (or is this just a
> Is there some way to keep a newly-created monitor from grabbing the
> focus?
You'll have to configure your window manager for this.
> I'd also like it if the active monitor were alway "on top" of the display
> and if it were possible to select a monitor (as with d.mon select=x*) with
> the mouse just by clicking it to give it the input focus. That is, the
> "top" monitor is always selected, and the selected monitor is always "on
> top". Again, this may be behavior specific to the window manager. If so,
> then too bad.
The notions of focus and stacking are controlled by the window
manager. While it is technically possible that some X-aware GRASS
program could search up and down the window stack to find the top-most
monitor and draw to it, this would be a very bad idea for several
reasons, (including the fact that many window managers allow "active"
windows that are under other windows).
> Even better, could we give the monitor windows a default action in
> response to mouse clicks, double clicks, drags and so on? I'd like it if
> the monitor came up with the functionality of d.where, d.zoom, d.erase or
> d.what.* already running and available with just a mouse action on the
> monitor.
I think something like this would be a great idea. As far as
implementation, it probably makes sense to leave the monitors as "dumb
displays", but a new program could be written that provides a window
for a GRASS monitor and also provides this kind of functionality.
I plan to start experimenting with such programs right away.
-Carl
Carl Worth
USC Information Sciences Institute cworth at east.isi.edu
3811 N. Fairfax Dr. #200, Arlington VA 22203 703-812-3725
