[GRASS5] A problem with the proj library?
Eric G. Miller
egm2 at jps.net
Sat Feb 9 21:13:38 EST 2002
On Sat, 9 Feb 2002 09:10:14 -0700, Roger Miller <rgrmill at rt66.com> wrote:
[snip]
> Also, the input UTM coordinates in this case are supposed to be significant
> to about 8 digits. The surveyors actually quoted the northings to 9 digits.
> The conversion constant of 0.3048000000 that GRASS stuck in my PROJ_UNITS
> files would introduce a usually unacceptable error in the meters->feet
> conversion. We probably need a more precise constant built into the source.
> I think 0.3048006096012 is about right.
If we're going to be precise, then we'd need to differentiate which type
of foot we're talking about:
foot_type to_meters
Survey Foot | (1200/3937) (derived from: 1 m = 39.37 in)
Int. Foot | 0.3048 (derived from: 1 yd. = 0.9144 m)
1 Int. Foot = 0.999 998 Survey Foot
True, though, that for geodetic measures, it is usually the old foot, or
survey foot, that is meant.
Eric G. Miller <egm2 at jps.net>
