[GRASS5] [bug #917] (grass) r.neighbors
Request Tracker
grass-bugs at intevation.de
Sun Feb 10 08:08:50 EST 2002
this bug's URL: http://intevation.de/rt/webrt?serial_num=917
Markus
I am now at r.neighbors - from the text and from the manual it appears that it
does not support floating point input and output - is that right? If yes it should be
updated ASAP.
Helena
--- Headers Follow ---
>From neteler at itc.it Sun Feb 10 14:08:42 2002
Return-Path: <neteler at itc.it>
Delivered-To: grass-bugs at lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
by lists.intevation.de (Postfix) with ESMTP id 7C81613949
for <grass-bugs at lists.intevation.de>; Sun, 10 Feb 2002 14:08:42 +0100 (CET)
Received: from camelot.itc.it (camelot.itc.it [195.223.171.5])
by mail.intevation.de (Postfix) with ESMTP id 7C7D01B6BB
for <grass-bugs at intevation.de>; Sun, 10 Feb 2002 14:08:41 +0100 (CET)
Received: from artemide.itc.it (artemide [10.0.10.10])
by camelot.itc.it (8.11.3/8.11.3) with ESMTP id g1AD8er12453
for <grass-bugs at intevation.de>; Sun, 10 Feb 2002 14:08:40 +0100 (MET)
Received: from thuille.itc.it. (thuille [10.40.0.110])
by artemide.itc.it (8.11.3/8.11.3) with ESMTP id g1AD8d514654
for <grass-bugs at intevation.de>; Sun, 10 Feb 2002 14:08:39 +0100 (MET)
Received: (from neteler at localhost)
by thuille.itc.it. (8.11.6/8.11.2) id g1AD8cm07565
for grass-bugs at intevation.de; Sun, 10 Feb 2002 14:08:38 +0100
Resent-Message-Id: <200202101308.g1AD8cm07565 at thuille.itc.it.>
Received: from camelot.itc.it (camelot [195.223.171.5])
by artemide.itc.it (8.11.3/8.11.3) with ESMTP id g1A0EN520223
for <neteler at itc.it>; Sun, 10 Feb 2002 01:14:24 +0100 (MET)
Received: from mail5.nc.rr.com ([24.93.67.52])
by camelot.itc.it (8.11.3/8.11.3) with ESMTP id g1A0EMr09475
for <neteler at itc.it>; Sun, 10 Feb 2002 01:14:22 +0100 (MET)
Received: from unity.ncsu.edu ([66.26.232.232]) by mail5.nc.rr.com with Microsoft SMTPSVC(5.5.1877.687.68);
Sat, 9 Feb 2002 19:13:01 -0500
Sender: helena at itc.it
Message-ID: <3C65AE9F.F8084DA at unity.ncsu.edu>
Date: Sat, 09 Feb 2002 17:19:59 -0600
Organization: NCSU
X-Mailer: Mozilla 4.73 [en] (X11; U; Linux 2.2.16-3 i686)
X-Accept-Language: en
MIME-Version: 1.0
To: Markus Neteler <neteler at itc.it>
Subject: r.neighbors
References: <20020128141530.R22545 at itc.it> <3C5777DF.2DEBF7B3 at unity.ncsu.edu> <20020130085753.O22545 at itc.it> <3C582118.51337968 at unity.ncsu.edu> <20020130164008.D23306 at itc.it> <3C5DEAF0.95BB64D1 at unity.ncsu.edu> <20020204183631.A15562 at itc.it> <3C5FD778.A4AF5388 at unity.ncsu.edu> <20020205170357.F19523 at itc.it> <3C63E9AD.50FC2688 at unity.ncsu.edu> <20020209002318.A27525 at thuille.itc.it>
Content-Type: text/plain; charset=us-ascii
Content-Transfer-Encoding: 7bit
Resent-From: neteler at itc.it
Resent-Date: Sun, 10 Feb 2002 14:08:38 +0100
Resent-To: grass-bugs at intevation.de
X-Spam-Status: No, hits=0 required=5 tests=
-------------------------------------------- Managed by Request Tracker
