[GRASS5] Using 'vask' library
Markus Neteler
neteler at itc.it
Tue Feb 12 04:42:30 EST 2002
On Tue, Feb 12, 2002 at 07:42:06AM +0000, Glynn Clements wrote:
> Markus Neteler wrote:
> > I have changed the old passage:
> [snip]
> > to (new):
> > \textbf{Note.} The target \textit{pgm} depends on the object files \$(OBJ)
> > and the \textit{Vask Library} \$(VASKLIB). This is done so that
> > modifications to any of the \$(OBJ) files or to the \$(VASKLIB) itself will
> > force module reloading. Linking against the Vask library is \$(VASKLIB)
> > \$(CURSES), it specifies both the UNIX curses and termcap/terminfo libraries
> > as well as \$(VASKLIB).
> > [sorry for the Latex markup]
> > Does this change make sense? If not, please correct, then I publish the
> > updated PDF.
> The phrase "Linking against the Vask library is \$(VASKLIB) \$(CURSES)"
> isn't grammatically correct. It should probably say something like
> "Linking against the Vask library is performed using \$(VASKLIB) \$(CURSES)"
> Apart from that, it's OK.
Thanks. The updated PDF is posted on the web site.
Markus
