[GRASS5] cp -L Problems with grass 5.1 Makefiles under Linux
Radim Blazek radim.blazek at wo.cz
Wed Feb 13 19:39:37 EST 2002
On Wednesday 13 February 2002 01:25, Tom Rake wrote:
>Today I tried to compile grass51 from cvs. I am using a Debian i386 box.
>I needed to change lib/ogsf/Makefile and visualization/nviz/Makefile to
> complete the compile. In all cases the problem was a cp with the -L which
> my gnu cp doesn't like. After removing the -L options I did a make
> distclean and the compile went to completion. I didn't check to see if my
> cp was current I believe it was Debian potato (current stable) Tom RakeDuff
> Map Company.
Thanks. I have removed that '-L'.
Radim
