[GRASS5] [bug #920] (grass) d.vect.line does not draw lines
Request Tracker grass-bugs at intevation.de
Fri Feb 15 05:59:05 EST 2002
this bug's URL: http://intevation.de/rt/webrt?serial_num=920
Subject: d.vect.line does not draw lines
Platform: Linux/Intel
Linux distro: Debian
linux cpu: Intel (i486, i586, pentium ...)
Xwindows version: Xfree 4.0.x
Xwindows manager: WindowMaker
TclTk version: tcl/tk 8.2
grass downloaded at: Trento site
grass binary for platform: I compiled the sources myself
grass sources source: exp_snap_13202
c compiler name: gcc
When I launch
d.vect.line mapname
I just get a line saying
drawing lines ... 0%
and then it exits without anything on the monitor.
With
d.vect mapname
I see the map, just as with
d.vect.area mapname
I had to compile d.vect.line individually with gmake5/gmakelinks5 after the general compilation with make (see relevant message in grass-developers list), so maybe that causes the problem.
-------------------------------------------- Managed by Request Tracker
