[GRASS5] Segfault in v.in.tig.lndmk
Markus Neteler
neteler at itc.it
Fri Feb 15 08:42:28 EST 2002
Thank, Tom!
I have applied the fix to both experimental and release branch.
Markus
On Thu, Feb 14, 2002 at 02:47:41PM -0500, Tom Rake wrote:
> Grass Developers,
> I found a Segfault in v.in.tig.lndmk. Here is a summary of my fault case and
> a patch that fixed this for me.
> My distro and grass source
> Debian/GNU Linux; grass CVS HEAD; (I believe the release branch should also
> have same fault - have not tested this ).
> Data used for fault case:
> http://www.census.gov/geo/www/tiger/tiger2k/ny/tgr36105.zip
> Setup this location:
> location: sullivan
> mapset: census
> UTM zone 18
> n=4805100
> s=4440000
> w=279100
> e=743900
> nsres=100
> ewres=100
> Make this file *fault.txt*
> .points hospitality
> D27
> .end
> .exit
> ***** End of fault.txt
> Run this grass command
> v.in.tig.lndmk t1=/dir/to/unziped/TGR36105.RT1 input=crash.txt
> My Analysis
> the Site_head info struct in open_site_file() from points.c failed to fully
> initialize the structure. The info.stime if non null garbage is taken by
> G_site_put_head() to me a valid structure.
> This Patch fully initializes the structure to NULLs.
> RCS file:
> /home/grass/grassrepository/grass/src/mapdev/v.in.tig.lndmk/points.c,v
> retrieving revision 1.2
> diff -c -r1.2 points.c
> *** points.c 12 Jan 2001 08:16:28 -0000 1.2
> --- points.c 14 Feb 2002 19:20:25 -0000
> *** 42,47 ****
> --- 42,53 ----
> FILE *fp1;
> Site_head info;
> + info.name = NULL;
> + info.desc = NULL;
> + info.form = NULL;
> + info.labels = NULL;
> + info.stime = NULL;
> + info.time = NULL;
> if (sitefile == NULL)
> if ((sitefile = G_fopen_sites_new (site_name)) == NULL)
> -Tom Rake
