[GRASS5] Re: [GRASS-CVS] CVS update: grass/src/display/devices/CELL
Glynn Clements glynn.clements at virgin.net
Sat Feb 16 15:35:31 EST 2002
Markus Neteler wrote:
> the recent changes to XDRIVER introduced a bug:
> Try:
> export GRASS_HEIGHT=100
> d.mon x0
>  using default visual which is TrueColor
>  ncolors: 65536
>  Graphics driver [x0] started
> d.mon stop=x0
> d.mon x0
>  X Error of failed request:  BadValue (integer parameter out of range for
>  operation)
[snip]
> Please pre-define the variable if unset (will also affect GRASS_WIDTH,
> unchecked).
OK, done.
> Then a question: Now PNGDriver and Xdriver use the same size variables
> GRASS_HEIGHT and GRASS_WIDTH (or not?).
Yes; all monitors now use these variables. The intention was to make
it easier for programs which manage monitors, so that they don't need
a table of which monitor uses which variables.
If you want per-monitor-type variables, it would be better to
generalise the mechanism using the driver name, e.g. with something
like GRASS_WIDTH_XDRIVER, GRASS_WIDTH_PNG, GRASS_WIDTH_CELL etc rather
than having a special case for one of the drivers.
Glynn Clements <glynn.clements at virgin.net>
