[GRASS5] Re: [GRASS-CVS] CVS update: grass/src/display/devices/CELL
Andreas Lange Andreas.Lange at Rhein-Main.de
Sun Feb 17 06:04:47 EST 2002
Markus Neteler wrote:
> > > the recent changes to XDRIVER introduced a bug:
> > [snip]
> [snip]
> > > Please pre-define the variable if unset (will also affect GRASS_WIDTH,
> > > unchecked).
> > OK, done.
> Thanks, working now.
> > > Then a question: Now PNGDriver and Xdriver use the same size variables
> > > GRASS_HEIGHT and GRASS_WIDTH (or not?).
> > Yes; all monitors now use these variables. The intention was to make
> > it easier for programs which manage monitors, so that they don't need
> > a table of which monitor uses which variables.
> > If you want per-monitor-type variables, it would be better to
> > generalise the mechanism using the driver name, e.g. with something
> > like GRASS_WIDTH_XDRIVER, GRASS_WIDTH_PNG, GRASS_WIDTH_CELL etc rather
> > than having a special case for one of the drivers.
> Well, what's preferred? Individual size variables for each driver or
> overall variables? Opinions?
one set of variables (GRASS_WIDTH, GRASS_HEIGHT) for all
monitors/drivers. IMHO one can change the variables after opening the
driver, so that new started monitors inherit the new values with their
environment.
Just my opinion.
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
url: http://mitglied.tripod.de/AndreasLange
mail: Andreas.Lange_at_Rhein-Main.de - A.C.Lange_at_GMX.net
