[GRASS5] [bug #920] (grass) d.vect.line does not draw lines
M Lennert
fa1079 at qmul.ac.uk
Sun Feb 17 08:06:48 EST 2002
Eric,
This does sound pretty complicated and I'm not sure it is really necessary to put all in one module. From my experience most of the time one would either be displaying and area file in which boundaries are
normally all the same color or a line file with different colors for different lines. So separating the two might be easier.
But if you we go for one unified d.vect:
> $ d.vect help
> Draws vector maps
> Usage:
> d.vect -aflv map=name [color=name] [fillcolor=name] [catnum=value[,value,...]]
couldn't you rather do the following (since I find the combination of -aflv plus different color options a bit confusing):
Usage:
d.vect map=name [color=name] [fillcolor=name] [acatnum=value[,value,...]] [lcatnum=value[,value,...]] [alegend=filename] [llegend=filename]
Where
if "fillcolor" then
if "acatnum" then
fill acatnum areas with fillcolor
else
fill areas with fillcolor
end if
end if
if "linecolor" then
if "lcatnum" then
draw lcatnum lines with linecolor
else
draw all labelled lines with linecolor
end if
end if
if "color" then
draw all lines (area boundary or not) with color
end if
alegend = legend for areas
llegend = legend for labelled lines
It would be interesting to be able to give an alegend file but still give a "color" option to define the boundary lines color.
default, i.e. 'd.vect mapname' : no fillcolor and white line color for all lines
Just for information: the drawing of the boundaries with d.vect.area is much slower than when done through d.vect. Any idea why ?
Moritz
