[GRASS5] v.in.mif
Heiko Kehlenbrink
heiko.kehlenbrink at vermes.fh-oldenburg.de
Mon Feb 18 07:04:34 EST 2002
Hi all,
i had just imported the 9023.MIF/MID files into GRASS from
www.english-nature.org.uk/pubs/gis .
I used this Region:
REGION FACILITY
CURRENT REGION: N=732954 S=0 RES=1 ROWS=732954
E=730403 W=0 RES=1 COLS=730403
PROJECTION: 99 (Transverse Mercator)
ZONE: 0
DATUM: osgb36
ELLIPSOID: airy
First thing i had to do was rename the files from 9023.MIF and 9023.MID
to 9023.mif and 9023.mid.
Than i had to add a logfile output(otherwise v.in.mif ended without
producing anything, not even an error), maybe it would be a good idea to
pipe the logging-output to nirwana
by default?
GRASS:~ > v.in.mif input=/home/heiko/grassdaten/britain/9023NA.mif
output=9023MIF logfile=/tmp/miflog.txt
WARNING: Duplicate ring added.
WARNING: You must run `v.support option=build' on
this (these) map(s) to build the topology.
GRASS:~ > v.support map=9023MIF option=build
V.SUPPORT:
Selected information from vector header
Organization:
Map Name: 9023MIF
Source Date:
Orig. Scale: 200
No snapping will be done
Reading Vector file 100%
Building areas 100%
Building islands 100%
Attaching labels
PNT_TO_AREA failed: (487645.986637, 421993.662174) (Category 27)
PNT_TO_AREA failed: (472080.339655, 415630.182221) (Category 28)
PNT_TO_AREA failed: (396831.840312, 347753.296154) (Category 36)
WARNING: area 62 label: 31 matched another label: 42.
PNT_TO_AREA failed: (506536.608376, 386967.204960) (Category 43)
PNT_TO_AREA failed: (413584.035007, 333139.904697) (Category 49)
PNT_TO_AREA failed: (652335.198233, 303559.020389) (Category 58)
PNT_TO_AREA failed: (646401.438483, 309376.050000) (Category 60)
PNT_TO_AREA failed: (646401.438483, 309376.050000) (Category 61)
WARNING: area 183 label: 66 matched another label: 67.
WARNING: area 180 label: 78 matched another label: 79.
PNT_TO_AREA failed: (541797.631173, 190794.412779) (Category 81)
PNT_TO_AREA failed: (608065.746866, 154680.930000) (Category 92)
PNT_TO_AREA failed: (571502.343881, 162589.318863) (Category 93)
PNT_TO_AREA failed: (571502.343881, 162589.318863) (Category 95)
PNT_TO_AREA failed: (453538.667104, 142008.500280) (Category 104)
WARNING: area 176 label: 114 matched another label: 117.
WARNING: area 174 label: 119 matched another label: 121.
WARNING: area 8 label: 123 matched another label: 124.
WARNING: area 172 label: 128 matched another label: 130.
WARNING: area 143 label: 206 matched another label: 207.
WARNING: area 143 label: 207 matched another label: 208.
Number of lines: 424
Number of nodes: 306
Number of areas: 188
Number of isles: 92
Number of atts : 196
Number of unattached atts : 13
Snapped lines : 0
After that v.in.mif worked for me , produced a Logfile containing:
Mapinfo Data File:
VERSION: 300
DELIMITER: ,
Projection info: Earth Projection 8, 79, "m", -2, 49, 0.9996012717,
400000, -100000 Bounds (-7845061.1011, -15524202.1641) (8645061.1011,
4470074.53373)
Field data -- 2 columns
Field 0 is nacode of type Integer
Field 1 is naname of type Char
I also tried to import the Field 1 data with :
output=9023MIF logfile=/tmp/miflog.txt attribute=naname
or
output=9023MIF logfile=/tmp/miflog.txt attribute=Field1
but failed.
Any suggestions about the warnings,
PNT_TO_AREA failed -lines and the Field Data?
Best Regards
Heiko Kehlenbrink
