[GRASS5] [bug #920] (grass) d.vect.line does not draw lines
Eric G. Miller egm2 at jps.net
Mon Feb 18 17:10:29 EST 2002
On Mon, Feb 18, 2002 at 10:44:01AM +0000, M Lennert wrote:
> On 17 Feb 02, at 12:58, Eric G. Miller wrote:
> > I have no problem with that formulation.  I'd like to get some
> > consensus on whether people feel one or several modules are appropriate.
> I would prefer seperate modules.
Me too.
> I was actually talking about the part after the "rewind", i.e. once
> the areas have been filled and the module draws the boundaries. At
> least in the example I am working right now, this second part takes
> longer than when I draw the boundaries with d.vect.
I'll look into it.  Need to make some changes for just drawing
boundaries anyway (fillcolor=none).
Eric G. Miller <egm2 at jps.net>
