[GRASS5] dalloc.c, svd.c ?? linked list code ??
David D Gray
ddgray at armadce.demon.co.uk
Sun Feb 24 21:09:12 EST 2002
Eric G. Miller wrote:
> On Sun, Feb 24, 2002 at 10:24:49PM +0000, David D Gray wrote:
>>Eric
>>I am preparing a graph -like thing, as part of the import filter, and
>>maybe for other purposes. It is doubly linked so would do for a
>>doubl-linked list, by just using n_vertices = 2. It doesn't have any
>>functions other than the linking, but other things could be added. There
>>is already an example in v.in.shape/mif, but it's sort of hard-wired
>>into these functions so not much use for general-purpose.
> A graph is a bit different from a run of the mill linked list. I think
> it'd be useful to have both.
Yes. It would be useful to build up a full set of standard containers in C.
David
