[GRASS5] [bug #927] (grass) r.mapcalc3 does not compile on solaris 8/SPARC
Glynn Clements
glynn.clements at virgin.net
Tue Feb 26 17:12:14 EST 2002
Request Tracker wrote:
> Subject: r.mapcalc3 does not compile on solaris 8/SPARC
> gcc -I/opt2/grass50/grass/src/include -g -O2 -I/usr/local/include -c xabs.c -o OBJ.sparc-sun-solaris2.8/xabs.o
> In file included from xabs.c:4:
> expression.h:87: `single' redeclared as different kind of symbol
> /usr/include/floatingpoint.h:62: previous declaration of `single'
OK, thanks for the info; I'll rename that function.
> r.mapcalc3 does not compile. Is this ok that it is in the default
> compile list?
That's the only way that platform-specific problems like this will be
discovered.
Glynn Clements <glynn.clements at virgin.net>
