[GRASS5] How to change a colortable in fp maps?... and another d.colors issue
Gualter Barbas Baptista
gualter at netcabo.pt
Tue Feb 26 22:31:15 EST 2002
I just figured out that there is no support for fp in d.colors too. Is
there any way to do this (except multiplying and converting to int)?
Another thing with d.colors: I didn't figure how to change the colors
for negative numbers. It only asks me for the maximum category, so, for
example, if I have values ranging from -10 to 10 (as I had in a NDVI), I
can only change the colors for the categories ranging from 0 to 10. I
wanted to give the values ranging from -10 to -1 the color blue (water).
Any solution to this?
Thanks,
Gualter
