[GRASS5] Re: [GRASSLIST:2833] core dumps after i.rectify
frank at gevaerts.be
Tue Jan 1 13:31:23 EST 2002
On Tue, 1 Jan 2002, Eric G. Miller wrote:
<clipped>
> Alright, the problem seems to be that in "exec.c", G_put_cellhd() is
> called after the raster has been written. I think it is entirely
> unnecessary (and obviously screws up some critical info). I created
> an integer test file (floats didn't seem to be affected), and after
> commenting the G_put_cellhd() call, the rectified image doesn't
> cause a segfault. Would others care to try... ?
It seems to work here
Frank
> It's around, line 75 or so...
> if (rectify (name, mapset, result,order))
> select_target_env();
> /* G_put_cellhd (result,&target_window); */
> if(cats_ok)
> Eric G. Miller <egm2 at jps.net>
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
HI! I'm a .signature virus! cp me into your .signature file to help me spread!
