[GRASS5] m.in.e00: raster import and ESRI NULL values
Markus Neteler
neteler at itc.it
Fri Jan 4 10:15:50 EST 2002
Dear developers,
a (not unknown) problem I have run into today: When importing
E00 raster data with m.in.e00, the module doesn't catch the
ESRI NULL value properly:
r.info wakedem30
| Range of data: min = -340282306073709652508363335590014353408.000000|
Some time ago, I have written details into
src/misc/m.in.e00/TODO:
such as
GRD 2 meaning single precision float values, you have only 7 significant
digits, so -0.3402823E+39 is a good value to use.
Unfortunately I don't get the change coded in C to read the actual
ESRI NULL value from the E00 file. The secrets are explained in
TODO, it would be great if someone could fix the problem.
Thanks!
Markus
