[GRASS5] v.out.shape bug
David D Gray
ddgray at armadce.demon.co.uk
Sun Jan 6 12:36:31 EST 2002
Hi Markus,
OK! I'll check in the changes. There seems to have been a lot of
commenting out calls to free and other cleanup ops. I then find the
segfault just moves to a `realloc' call - so, there seems to be some
upstream overflow or similar, which I presume is responsible for many of
the problems. I've moved the declaration of P_AREA *Area out to static
which seems to work OK, but I still can't call `free()' on Area without
getting a segfault. This isn't particularly good style and it's just a
workaround but at least it moves us on a step.
David
Markus Neteler wrote:
> For us here at IRST the current CVS version causes a lot of problems
> (sorry to say this).
> If you just try
> Spearfish location
> v.out.shape roads
> v.in.shape roads.shp
> that's also not working. So we'll appreciate an update!
> Best regards
> Markus
