[GRASS5] Grass 5.1
Glynn Clements
glynn.clements at virgin.net
Mon Jan 7 07:20:46 EST 2002
Radim Blazek wrote:
> 2) Debug
> New function G_debug (int level, char * msg) prints message if enviroment
> variable GRASS_DEBUG_LEVEL is set to level equal or higher.
> My proposal for levels is:
> * Levels: (recommended levels)
> * 1 - messages printed once or few times per module
> * 3 - each row (raster) or line (vector)
> * 5 - each cell (raster) or point (vector)
> and I use optional compilation (speed):
> #ifdef GDEBUG
> G_debug (1, "Vect_open_old(): name = %s mapset= %s", name, mapset);
> #endif
Too much of this can make the code messy. Parameter tracing is usually
better performed with gdb command sequences, e.g.
break Vect_open_old
commands
silent
printf "Vect_open_old(): name = %s mapset= %s", name, mapset
continue
end
Unfortunately, it isn't straightforward to set a breakpoint in the
middle of a function without using line numbers (which need to be
updated whenever the source changes).
I do think that we should have something similar to G_warning() for
user messages, rather than just printing to stdout/stderr.
Glynn Clements <glynn.clements at virgin.net>
