[GRASS5] ./configure and --enable/--disable ??
Glynn Clements
glynn.clements at virgin.net
Wed Jan 16 11:37:25 EST 2002
Eric G. Miller wrote:
> How come --enable/--disable don't work anymore to turn on/off features?
> For instance:
> ./configure ... --disable-odbc
> doesn't work. But,
> ./configure ... --without-odbc
> does. It's rather confusing to have both the enable/disable and
> with/without switches, with some working for certain things and
> not for others.
A while back, I changed the namings to conform to the autoconf
documentation[1], which basically says that --with[out] controls the
use of external features/libraries, while --{en,dis}able controls the
use of features provided by the package.
[1] and to be consistent with other packages' configure scripts.
So, the following are controlled by --{en,dis}able:
--enable-sysv define the compiler macro SYSV
--enable-another-button use two-button mouse conveniently
--enable-socket use socket XDriver (default)
--enable-fifo use FIFO XDriver instead of sockets
--enable-w11 use W11 library for Windows X11 emulation
Everything else (i.e. library dependencies) uses --with[out].
Glynn Clements <glynn.clements at virgin.net>
