[GRASS5] [bug #894] (grass) g.list doesn't work
Markus Neteler neteler at itc.it
Thu Jan 17 12:00:17 EST 2002
On Thu, Jan 17, 2002 at 05:04:14PM +0100, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=894
> Subject: g.list doesn't work
> Platform: Windows NT, 2000
> Xwindows version: xfree86 4.1.0
> TclTk version: tcl/tk 8.0.5
> grass downloaded at: Trento site
> grass binary for platform: Linux/Intel binaries
> I installed grass for windows on a windows NT and a windows2000 machine.
> Grass works fine from the cygwin shell and from the xfree server.
> The command g.list doesn't work from the command line of the cygwin shell and it doesn't work from the command line on the xfree server.
> The file /usr/local/grass5/bin/g.list is availabel.
> On the windows2000 machine the tcl/tk works. And by using the menu I can get a list of the available files (raster, vector, ...). Then I can choose and display these files.
this sounds like the less=more problem.
Try to set
export GRASS_PAGER=less
g.list rast
If working, we should consider to predefine GRASS_PAGER to less
under cygwin.
Markus
