[GRASS5] [bug #895] (grass) changing monitor dimensions does not change x0
Request Tracker grass-bugs at intevation.de
Fri Jan 18 08:57:55 EST 2002
this bug's URL: http://intevation.de/rt/webrt?serial_num=895
Subject: changing monitor dimensions does not change x0
Platform: Linux/Intel
Linux distro: Debian
linux cpu: Intel (i486, i586, pentium ...)
Xwindows version: Xfree 4.0.x
Xwindows manager: WindowMaker
TclTk version: tcl/tk 8.2
grass downloaded at: Trento site
grass binary for platform: I compiled the sources myself
grass sources source: GRASS 5.0.0pre3
c compiler name: gcc
When changing the default display dimension using tcltkgrass (through the config menu), all displays will use these new dimensions except for x0 which stays at the previously defined size, even after quitting grass5 and restarting.
-------------------------------------------- Managed by Request Tracker
