[GRASS5] r.slope.aspect crash - libes/gis/null_data.c
Helena
hmitaso at unity.ncsu.edu
Fri Jan 18 14:38:15 EST 2002
Markus
when you give it both curvatures it runs, when you give it only pc curvature
it crashes. So this looks as another unfinished enhancement and genuine bug. I do
not have time to look at
it untill Feb.1, but somebody else may be able to fix it (and add the colortable
from rst too).
Helena
GRASS:~ > r.slope.aspect bh02dec01.t800 slope=slp.test aspect=asp.test pcur=pc.test
percent complete: Segmentation fault (core dumped)
tcur=tc.test
percent complete: 100%
CREATING SUPPORT FILES
ELEVATION PRODUCTS for mapset [helena] in [jockey-state]
min computed aspect 0.0019 max computed aspect 359.9997
Color table for [asp.test] set to aspect
ASPECT [asp.test] COMPLETE
min computed slope 0.0000 max computed slope 9.9895
SLOPE [slp.test] COMPLETE
PROFILE CURVE [pc.test] COMPLETE
TANGENTIAL CURVE [tc.test] COMPLETE
Neteler wrote:
> (cc RT)
> On Fri, Jan 18, 2002 at 11:09:36AM -0500, Helena Mitasova wrote:
> > Markus
> > I used r.slope.aspect for curvatures quite a bit and did not have a problem
> > (except that it does not write the custom color table as the rst programs do
> > which is annoying)
> > - I will test it too, but I want to ask whether you had a mask set, because I
> > might not have used it with a mask.
> > Helena
> ...no, I didn't:
> GRASS:~ >g.list rast |grep MASK
> GRASS:~ >
> It can be even replicated with the Spearfish data.
> Markus
> > (If you are computing it to visualize the waves along contours, I am covering
> > that in the applications, so do not worry about that right now)
> > Neteler wrote:
> > > Hi,
> > > today we realized a nice crash of r.slope.aspect:
> > > r.slope.aspect elev pc=z.rsa.pcurf
> > > If you try the spearfish data:
> > > r.slope.aspect elevation.dem pc=z.rsa.pcurf
> > > The debugger tells us that there is something strange in
> > > Program received signal SIGSEGV, Segmentation fault.
> > > 0x8056635 in G_set_f_null_value (fcellVals=0x0, numVals=1) at null_val.c:295
> > > /ssi0/ssi/neteler/cvsgrass/src/libes/gis/null_val.c:295:9157:beg:0x8056635
> > > (gdb)
> > > Unfortunately this doesn't tell me anything? Probably the NULL
> > > implemenation is weird in null_val.c?
> > > To our surprise the aspect/slope calculation runs well.
> > > It would be nice to have that fixed...
> > > Thanks,
> > > Markus
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
