[GRASS5] Fertilizer 2002: CVS and release strategies
Glynn Clements glynn.clements at virgin.net
Sat Jan 19 21:03:44 EST 2002
Bernhard Reiter wrote:
> * Each change commited to the release branch must be immediately
>    commited to the main branch. If change in stable branch was
>    not commited to development branch, developer will be asked to do that
>    via mailing list.
This isn't always as straightforward as the preceding paragraph
implies.
If someone has been modifying the corresponding program/library on the
development branch (trunk), a fix which works for the stable version
may not work on (or even apply to) the development version. If the
development version has changed significantly and/or is in a state of
flux, someone who can produce a fix for the stable version might not
be able to determine a suitable fix for the development version.
Glynn Clements <glynn.clements at virgin.net>
