[GRASS5] CVS Merge
Glynn Clements
glynn.clements at virgin.net
Tue Jan 22 02:51:00 EST 2002
I have now merged the changes to the release branch into the head.
AFAICT, any file which exists in the release branch also exists in the
head, and both versions are identical (apart from differences due to
CVS keyword expansion, e.g. $Date, $Id, $Log etc).
OTOH, many files only exist in the head. Some of them should probably
be removed, while others should remain. In general:
1. Files which aren't currently being used, e.g. because of bugs, but
which might be used eventually should remain.
2. Files which have been made obsolete or which are otherwise unlikely
to ever be used should be removed.
Comments regarding which files fall into which category are
appreciated.
Glynn Clements <glynn.clements at virgin.net>
