[GRASS5] problem with grasslinks
Alex Shevlakov alex at asrv.fcpf.ru
Tue Jan 22 07:59:46 EST 2002
Hi
at least tested to work on one server
grasslinks-reimplemented prog called 'webgrass'
You may wish to try that one on:
http://tigers.ru/webgrass_e/index.html
and take the source at
http://tigers.ru/webgrass_e.tar.gz
Hint: check write permissions for the apache user ( often it is 'nobody') for the tmp directory where
temporary files are stored.
Good luck
--alex
--- Anand Mohan <anand at mail.arkinsys.com> wrote:
> hi
>  Iam working with grass and grasslinks. I am not
> able to display the selected map in the browser.In
> create_gif subroutine gif is creating under tmp file
> with out any data in the file.can any body help me
> in this regard what may be the problem.I observed
> that paint.ppm file is not there under home
> directory.is it create dynamically.please help me in
> this regard.
> Thanks & Regards
> Anand Mohan G
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020122/1cdbcdb4/attachment.bin
