[GRASS5] CVS Merge
Glynn Clements glynn.clements at virgin.net
Tue Jan 22 17:10:37 EST 2002
Glynn Clements wrote:
> > Then, probably I am missing something: Are the files which have
> > been deleted on release_branch also gone on exp? Or are they
> > mixed into the working code? Sorry for this naive question.
> It appears that some have gone and some remain. I'm not sure what the
> deciding factor is; I'm wondering if it has something to do with the
> tag snafu that occurred last August. AFAICT, any files which were
> removed from the release branch *should* have been removed by the
> merge.
I've attached a list of files which have been added, removed, or not
removed by the merge.
Glynn Clements <glynn.clements at virgin.net>
Type: application/octet-stream
Desc: Changes due to merge
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020122/411e617e/changes.txt.obj
